Thread: Prius 75-91mpg
Old 12-23-2019, 12:59 AM   #127 (permalink)
Nathan jones
Ecomodding Apprentice
New rear door, as a guess around 3kg but will weigh before it gets glued on. Over the holiday I hope to get that done and the other side. I idealised for 1500g but it is stronger than needed so might go for 5 sheets 200g on the passenger side, or maybe 4 with some 1" pillars. That is more time consuming and I dont have much time off so I think 2.2kg will be it. With stucture I think the weight can be around 40% off compared to a thick main wall, even with a curve to it
It should loose 38kg all together with both doors and maybe 1.5kg of brackets and rubber trim
The Following User Says Thank You to Nathan jones For This Useful Post:
Ecky (12-23-2019)
