Old 10-19-2019, 01:46 AM   #121 (permalink)
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
Fuel Tank
Question for you ?
Does your Gen2 Prius have a metal fuel tank ? Just curious thanks
Old 12-03-2019, 12:36 PM   #122 (permalink)
Ecomodding Apprentice
Hi, not sure, plastic I believe, have thought of a smaller aluminium one, whys that?
The Following User Says Thank You to Nathan jones For This Useful Post:
TexasCotton (12-07-2019)
Old 12-03-2019, 12:40 PM   #123 (permalink)
Ill speak to my mot guy about wether it has to be outside the chassis, the most I put in is 14 litres and that does 3 days
Old 12-07-2019, 02:30 PM   #124 (permalink)
metal fuel tank Gen2 Prius /North America
Yeah
Most of the Prius Gen2 2004-09 years have a metal style fuel tank with a plastic bladder within. This means that if the fuel tank fails and or if the fuel pump fails you would have to replace the whole unit....
Several online people have commented that 2003-08 Toyota Corolla and Prius C(Aqua) have some shared platform characteristics....
Thanks
Old 12-23-2019, 01:31 AM   #125 (permalink)
Hi texas cotton, thanks for your reply but on mine its plastic, the fuel tank I mean. Im not sure where the pump as such is, it maybe with the level indicator which is accessed from above. Sorry for sporadic replies, I moved house and went on holiday alot
Old 12-23-2019, 01:49 AM   #126 (permalink)
Mpg which I will say is the ongoing day to day average, this includes temporary variables such as high/low wind, cold start mornings (including very flat batteries), races, urban/highway and with a warm winter ambient so it can be considered an all year mean is 102.29. I will achieve more when Ive researched better routing and traffic times to work, I now live further from work and travel 80 miles a day so I think approx 112 is possible with the car as it is
Old 12-23-2019, 01:59 AM   #127 (permalink)
New rear door, as a guess around 3kg but will weigh before it gets glued on. Over the holiday I hope to get that done and the other side. I idealised for 1500g but it is stronger than needed so might go for 5 sheets 200g on the passenger side, or maybe 4 with some 1" pillars. That is more time consuming and I dont have much time off so I think 2.2kg will be it. With stucture I think the weight can be around 40% off compared to a thick main wall, even with a curve to it
It should loose 38kg all together with both doors and maybe 1.5kg of brackets and rubber trim
Ecky (12-23-2019)
Old 12-23-2019, 02:00 AM   #128 (permalink)
Ecky (12-23-2019)
Old 12-23-2019, 02:04 AM   #129 (permalink)
Trimmed and ready to go. It was quick but next year might make much lighter ones
..Im going to put some 205/45's on the front (if theyre made) should give 55-45 drift when going quickly
or 45-55
Old 12-23-2019, 10:33 PM   #130 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.95 mpg (US)
I'm continually impressed by how far you've taken this. Keep it up!
