I recall that you’ve upgraded steering (now have ZERO play?), then it’s control over body motion that is the next step in reducing degree & duration of steering input. The minimum acceptable test is 3-seconds at 65-mph. On the count of three, are you on road or in ditch (crosswind tells truth)?
Optimize steering by:
1). HENDERSONS LINE-UP, for rear axle Panhard Rod (track bar).
2). ADDCO, for smallest rear anti-roll bar, plus up-sizing front bar smallest step (both required).
3). BILSTEIN 5100 a typical upgrade to stock shock absorbers, but better can be had. Controlling spring action vital to smooth (near-linear) steering response.
No bed wag, no body roll = less effort at all times, plus cleaner transitions per any application of what matters:
A). Steering
B). Brakes
C). Throttle
You’ve been focused on the least important of these attributes.
What can the truck do if we eliminate driver-introduced problems? A 2-300 mile loop with a 17-year old girl at wheel back to same pump otherwise on cruise control at 55 to 58-mph with ZERO acceleration, braking or lane-changing EXCEPT as law requires.
In other words, where is the baseline? (Which is lane-centered, steady-state. Cruise-control, no changes from this at all).
How many course corrections in 100-miles?
I’d bet it’s still SIGNIFICANTLY more than with the rack & pinion on mine.
Which would tell me there is still work to do.
But the test is needed. How one chooses to drive otherwise doesn’t matter. So long as the truck — left alone — is “better”. . . is what’s at stake.
Ever owned a rifle better than you? Same principle.
What can it do without hitting the 60-mph aero wall?
Any driver.
Simple rules
