Old 12-31-2019, 08:15 AM   #4 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Neutral safety switch can be replicated by clutch switch, OBD1 cars without full computer transmission don't care what transmission you use.
My experience with OBD2 Hondas which came from the factory with a manual, is that they don't care if there's even a transmission there. Gear ratio is calculated from RPM and speed.
Easiest way to do an auto to manual swap is to put in a manual ECU.
Xist (12-31-2019)
