When you get the hang of this you should swap to Arduino. Free programming interface, boards are like $10 now, and all of your high low temp guard, high low voltage guard, high low amp guard can all be programmed into the if-then statements of the program body. Its a lot of fun when you get in there. A lot of cheap and easy to implement sensors available.
Raspberry pi is fun too. You can set them up to output to a display as well for live info on your electric system.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
