Old 01-02-2020, 02:41 PM   #8079 (permalink)
Grant-53
Here is the problem with much of the conversations and debates on technical subjects. We don't always take the time to study the actual science using the scientific method and the Cause/Effect relationships. I worked in a research lab and had to do tests on Gorilla glass. It is tempting to do the same experiments over and over trying to get different results to support a theory. In reality we should evaluate the actual results to improve our hypotheses. We are dealing with conclusions based on correlations more often than cause and effect because the systems we are examining are complex. Good experiment design goes a long way in discovering the actual relationships. We have emissions systems on engines to reduce the production of NOx gas in the combustion process. Consider the angle of incidence for sunlight is different at higher latitudes. You are all intelligent enough to do research from open source materials and consult specialists. Books on chemistry, heat transfer, or meteorology are available. Research on the solar cycles is still ongoing. Data from ice cores and tree rings is being evaluated. Strange how the story of "The Emperor's New Clothes" is no longer popular.
The Genesis narrative is also ignored even though the evolutionists use the same order of creation.
The Following User Says Thank You to Grant-53 For This Useful Post:
aerohead (01-02-2020)
