Old 01-08-2020, 11:27 AM   #8124 (permalink)
aerohead
ground level pressure
It looks like scientists can detect air pressure changes at ground level at the poles in unison with the solar wind, lag time about 10 minutes.
So yeah the idea that "solar wind doesn't effect ground level" is so dead it's sad. Scientists knew this in the 60s, but some how it was forgotten, probably after they went to woodstock. The whole presumption that props up human driven climate change is that the suns output doesn't change, external influences can't effect the weather or climate, the earth is flat and the everything rotates around us, along with other nonsense. Anyone who says otherwise will be burned at the stake.
Soon man driven climate change will be just as dead.
I think they have always known this, otherwise they wouldn't be so hypocritical and hostile.
Yep,it's been long understood that,striking a vacuum will telegraph an intense pressure spike in a fully-compressible medium,all the way to the planet's surface.We'd hear it,if not for the fact that God tuned our ears such that they cannot detect the constant supersonic shockwaves coming through the atmosphere.
That's why all space craft immediately burn up in space,due to the skin friction up there.If you've ever seen crews returning to Earth,that's all faked.No one's ever been to space.It can't be done because of the solar wind.
NeilBlanchard (01-09-2020)
