Old 01-08-2020, 11:59 AM   #8127 (permalink)
aerohead
aerohead
Yes they use a report from 1996 that looked at 1 wavelength of UV who's output doesn't change. Thank aerohead for finding that report, he was so determined to prove that sun's output is fixed, he also exposed that's what the climate scientists were using all along. Opps.
The 2022 ipcc report will be the first to include outside influences.
Climate scientists have worked under the wrong assumption that the sun's output doesn't change and solar wind or cosmic particles can not effect weather or climate.
Times are a changing.
You probably don't want to put words in my mouth.See an eye doctor,or have that Asberger's Syndrome looked at.
Search for someone else to mischaracterize.I'll have you thrown off EcoModder.
