Old 01-11-2020, 10:21 AM   #43 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
My understanding of the gm truck hybrid transmissions is they are 4 speed transmission with electric motors at the input/output. The term "cvt" is a bit misleading imo, there is no slipping component as in Nissan CVT's.
And yes, I did back it up a moderate hill into our garage. No clutch slippage, all movement in reverse is powered by the output electric motor if I understand correctly.
https://en.m.wikipedia.org/wiki/Glob...id_Cooperation
"Although the transmission mechanically has only four conventional gear ratios, the electric motors allow it to function as a continuously variable transmission. This variable ratio functions in addition to the torque multiplication of the planetary gears."
