View Poll Results: Is my transmission running too cold?
Yes, get a thermostat! 1 50.00%
No, leave it alone! 1 50.00%
Voters: 2. You may not vote on this poll
Old 01-09-2020, 05:27 PM   #41 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
Originally Posted by EcoCivic View Post
I think you are confusing a CVT with a DCT. Most CVT transmissions use a torque converter (a fluid coupling) like a regular auto instead of a clutch, so they aren't harmed by crawling forwards or backwards. However, some CVTs like the ones found in some Hondas use a start clutch instead of a torque converter, so it's best to avoid crawling in those just like with a DCT.
A DCT (Dual clutch transmission) has no torque converter. Instead, it has clutches that may overheat from slipping and fail if you crawl for a long time, especially under load. The reason for this is because it can't fully engage the clutches until you reach a certain speed or the engine would stall (like letting the clutch out at too low of a speed in a manual transmission). Therefore, the clutches must slip. This quickly makes a lot of heat, which can destroy the clutches if done repetitively or for extended periods of time, especially under load.
couple people all ready blew up the reverse gear when towing good luck just trying to help you out from blowing yours up.. flat land is ok
NO backing up on a hill when towing.. it only took one of them 2 seconds to blow the reverse gear..
the reverse gear runs off the 60kw motor
powered by the engine >electrical power > 60kw motor
Old 01-10-2020, 02:58 PM   #42 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
I will say the Prius got stuck on a hill once. Decided to park down in a ditch like everyone else. There actually is no reverse gear. Just e motor. It would not do it. We had to push it. Lol
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 01-11-2020, 09:21 AM   #43 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
My understanding of the gm truck hybrid transmissions is they are 4 speed transmission with electric motors at the input/output. The term "cvt" is a bit misleading imo, there is no slipping component as in Nissan CVT's.
And yes, I did back it up a moderate hill into our garage. No clutch slippage, all movement in reverse is powered by the output electric motor if I understand correctly.
https://en.m.wikipedia.org/wiki/Glob...id_Cooperation
"Although the transmission mechanically has only four conventional gear ratios, the electric motors allow it to function as a continuously variable transmission. This variable ratio functions in addition to the torque multiplication of the planetary gears."
