Old 01-11-2020, 12:12 PM   #70 (permalink)
aerohead
40-45
Originally Posted by Tahoe_Hybrid View Post
that is wrong
this is a Real air dam
that is just a phony baloney ricer thing
I'm going to lower it all the way to the ground with air dams all the way around with Rubber so it's super flexible
the under body is too much of a mess it's call cutting a corner. :P also possibly a rear side skirt as well plus the tail gate mod
it should net me (35MPG hyw /39MPG city or so) (can sit in 4v DFCO longer)..
for some of the trip 35% i camped out behind a 18wheeler netted 27MPG..
while normally i can only get 24.5 by my self on the same route
if i did 100% of a trip behind a 18wheeler it can be in the 40-45MPG range ..
the vortex the 18wheeler makes allows me to get into 4v DFCO and stay in that mode or at lest Lean burn mode (it's equipped with PWM injectors) and FREE regeneration! as well.. to top it off!
there is a sweet spot behind it where you get free pull
by just aerodynamics alone, as it makes a vacuum..
just watch out some 18wheelers don't have this vacuum effect and could cost you in wasted fuel...
The V formation also works 'vortex surfing' to the left (prefered)or right lane of the trailer 1-2 car lengths behind does the job
this also helps out the trucker netting him better MPG as you become his boat tail. it's a win win!
Many years ago,at my aunt's home,I got to see an episode of Myth-Busters in which they drafted an 18-wheeler with a Chrysler sedan,indicating 42-mpg at close-quarters.Just be careful!
