Originally Posted by aerohead
'Urban Heat Island Effect' has been factored into the temperature records climatologists have used since the 1980s.Also,remote,terrestrial locations,far away from any urban development continue to warm.Out in the middle of the oceans.Tops of mountains.On the sea floor,under ice shelves.
PS The British will have official,Australian meteorological records,from the initial time of colonialism.Along with ship's records of air,water temperatures,and ocean currents.As well as declassified,cold war, naval,submarine records which recorded the entire water column,from operational deep depths, up to the surface.
That's a lie and easy to debunk.
If they had accounted for urban heat island effect then why does the new data set drop hundreds of temperature stations and only using 114 that are located in remote areas?
Oh a large portion of the sea temperature data like what was used in the "oceans and cryosphere report" has been thrown out too. Or retracted in nature which seems to be worse.
