Thanks again all!
I'm squarely in the Ioniq PHEV camp now. Only down side is there isn't a single 2020 (or 2019) PHEV available to test drive! Closest I've found is nearly 400 miles away. I reached out to a local dealer so hopefully they can procure one. They've got a hybrid on the lot but I imagine comparing an HEV to a PHEV is not really apples to apples.
A couple more questions for you all:
- Is there a good resource for info on the included chargers with the Ioniq PHEV? The only info I've found is that the Level 1 charger is 120V, 12A, 15-5P style connector, and IP55 rated. Nothing about the Level 2 other than I assume it is 240V!
- How does the internal kWh readout on the dash function? Is it lifetime? Or can it be reset every time I fill-up so per-tank kWh usage is tracked?
