Old 01-24-2020, 10:28 AM   #19 (permalink)
asciutto
Thanks for the info!
The actual charger is internal to the car. The charger in the Ioniq is 3.3 kW and is the limiting factor.
The car will come with a Level 1 110V ICCB which is basically a fancy extension cord. 110V x 12A = 1.3 kW. It will take about 9 hours to charge your battery.
I misspoke -- not charger, but charging cable. All documentation I've read points to the Ioniq coming with a Level 1 and a Level 2 charging cable. Beyond that there is very little information out there about the specifics.
IE: Plug-type, IP rating, etc.
Thanks again!
