Old 01-24-2020, 11:20 PM   #25 (permalink)
racprops
bradington...you have not said what all this has done in improving your MPG. What was your car doing when you started?? And what is your best during you best days/week??
I tested HHO on a 2000 Mercury grand Marques, I got nothing.
That car got 30MPG @ 65MPH I first drove 300 Miles stock to confirm 30MPG @ 65MPH..then did testing with a flying reading, as in I hit 65MPH hit cruse and reset my MPGunio and read the MPG until pull off and turn around.
The only thing that worked was running a 16.4 A/F ratio and that gave 35MPG at 65MPH.
And the most HHO I was able to get was 6 liters per minute, and that drew 30 AMPs and was draining my battery and could not be used after dark.
I tested three HHO systems none worked. I even got a bottle of pure hydrogen and it made no differences...And I had the eifi system to tune every important sensor.
I also had exhaust temp monitors and injector duty cycle read outs.
Cold gas vaporizers can only pull the light parts of gasoline leaving you with sludge...
Hot gas vaporizers are VERY dangerous and can blow up your car.
Rich
