Originally Posted by bradlington
For our older vehicles with narrow band O2 sensors that switch at the 0,45 V to indicate rich /lean -can future code include a possible indication in one of the corners to indicate if the O2 is reading rich /lean .
Facility via menu to enable or disable readings or indicator or both .
Thanks in advance
Bradley
Good idea
I haven't thought about doing this myself as all experience ive had with the closed loop systems Toyota run are very tidy on the air/fuel ratio. Basically its a constant teeter between rich/lean when in closed loop and punching the throttle always shows rich.
I could program in a red/green flashing box, that stays red when the speed is >0 and the fuel usage is >average :P aha then it'd be a wireless feature
