Old 01-28-2020, 01:58 AM   #30 (permalink)
bradlington
Thanks for the information .
Yes I have a PWM to control the HHO which is mounted in the drive area.
I have an Efie ,MAP enhancer and IAT control .
My ECU is the really clever and throw what you want at it and it corrects itself .
Only the MAP enhancer allows some leeway where on open road I can lean out if under slight load ,otherwise it slowly corrects back to 14,7 on my aftermarket AFR .
The only way I am going to gain anything is altering my mapping which there is a good offset BUT my ECU there are no stock maps available and even the big professional tuning companies are not wanting to touch this year / model .Same response from many - not supported OR our software does not support that year .
The heated fuel is still something to consider with proper testing .I was really worried about the and loss of economy last time so rolled back .
For now I have some other priorities so the car mods are going to take a secondary focus for a while .
The Following User Says Thank You to bradlington For This Useful Post:
Ecky (01-28-2020)
