Worth mentioning...
HAH pack is unique in that the main terminals are live when the breaker is on. With all the other Honda NiMH packs, there is a relay that must be engaged by the car in order to make one of the terminals hot. The HAH is unique in this regard. There is a safety by which the cover can't be removed unless the switch is off, but be extremely careful working with this pack.
Additionally, the activities at Insight Central are pretty much irrelevant to the HAH. No one is working on a Lithium pack for it. No one is offering enhanced control of the battery (MIMA, OBDIIC&C, etc.), and your options are to try and fix your pack or replace it with one filled with reconditioned Honda sticks or new Chinese sticks.
If you attempt to fix your pack via the typical reconditioning process described on the interwebz, you need to be okay with repeating it every 2 weeks to 3 months depending on the condition of the battery.
Grid charge/discharge is like a better solution. IF the battery can be improved by stick cycling, this will improve it. If it can't be improved, you've wasted far less of your life wasting your time.
Good luck
