Old 02-01-2020, 04:42 PM   #66 (permalink)
RedDevil
90 day: 55.8 mpg (US)
It is not just about failing, at least not about the result part of failing.
It is about not assuming you're right at whatever you do by default. "You should take the approach that you’re wrong. Your goal is to be less wrong."
You must be open minded and willing to accept that you can be wrong.
Criticism and advice from friends and failure to achieve something will point out where you're wrong, where you can improve the situation - if you are willing to take it in.
It is bloody essential, there's no substitute.
I'm fully aware that I may be wrong though
The Following 2 Users Say Thank You to RedDevil For This Useful Post:
freebeard (02-01-2020), redpoint5 (02-02-2020)
