Old 02-02-2020, 03:05 AM   #72 (permalink)
Xist
Hey Freebeard, I looked long and hard and found the source that I originally mentioned. Since you wanted all of the numbers, have all of the numbers! I am not even making you click on any links! If you complain now it is only because it is clearly a hobby!
Garage Door Replacement: 97.5%
Manufactured Stone Veneer: 94.9%
Minor Kitchen Remodel | Midrange: 80.5%
Deck Addition | Wood: 75.6%
Siding Replacement: 75.6%
Entry Door Replacement | Steel: 74.9%
Window Replacement | Vinyl: 73.4%
Grand Entrance | Fiberglass: 71.9%
Window Replacement | Wood: 70.8%
Deck Addition | Composite: 69.1%
Roofing Replacement | Asphalt Shingles: 68.2%
Bath Remodel | Midrange: 67.2%
Bath Remodel | Universal Design: 62.5%
Major Kitchen Remodel | Midrange: 62.1%
Roofing Replacement | Metal: 60.9% -
Bathroom Addition | Midrange: 60.6%
Bath Remodel | Upscale: 60.2%
Major Kitchen Remodel | Upscale: 59.7%
Master Suite Addition | Midrange: 59.4%
Bathroom Addition | Upscale: 58.1%
Backyard Patio: 55.2%
Master Suite Addition | Upscale: 50.4%
It shows Entry Door Replacement | Steel at 96.6% in 2014 and 101.8% in 2015, so I probably saw this 2014 - 2015. I do not have any idea why the data differs from Zillow, but this is pretty thorough. It breaks up the U.S. map into nine regions and then you can select major cities--if you sign up.
The top of the page says:
This site compares average cost for 30 popular remodeling projects with the value those projects retain at resale in 100 U.S. markets. Check out this year's trends and how they compare to prior years.
https://www.remodeling.hw.net/cost-vs-value/2019/
Edit: Zillow doesn't collect their own data, they use hw.net, so why are the results different?
freebeard (02-02-2020)
