Old 02-03-2020, 12:19 PM   #12 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
I don't think catalytic converters effect car fuel economy at all or barely at all.
After driving my electric so much I think fuel burners all stink. If you want to reduce back pressure removing the muffler and running just a converter would be better.
I would agree but only when the car is designed to run a cat. What if because you didn't have to worry about heating up a cat you could run completely different A/F ratios? Run different timing and compression then designed for the lean burn too. I think there are a bunch of non-starters in potential economy boosters because of that rich fuel mixture the cat needs.
