What's your excuse when the solar maximum is back in play...
You are conflating things, again....
Are we at a "solar maximum"?
I see a simple misapprehension.
Via Suspicious 0bservers this morning:
earthobservatory.nasa.gov: Global Green Up Slows Warming
Via Mac OS Summarize:
For example, Svalbard in the high-Arctic has seen a 30 percent increase in greenness, according to Rama Nemani of NASA’s Ames Research Center, a co-author of the review paper in Nature Reviews Earth & Environment.
...There is an interesting consequence of this global green up: as vegetation consumes some of the heat-trapping carbon dioxide it also performs evapotranspiration—a function similar to human sweating—which can have a cooling effect on the air.
...“It is ironic that the very same carbon emissions responsible for harmful changes to climate are also fertilizing plant growth,” said co-author Jarle Bjerke of the Norwegian Institute for Nature Research, “which in turn is somewhat moderating global warming.”
...The second map shows what the green-up might look like in the future based on the Coupled Model Intercomparison Project (CMIP5) climate model, under a scenario in which increases in greenhouse gases lead to almost 5° Celsius (9° Fahrenheit) of warming by the end of the 21st century.
