Old 02-20-2020, 09:39 AM   #2 (permalink)
oil pan 4
The only way the fuel pump would dump more fuel into the engine is if it was set to a higher pressure than the last one and that fuel pressure can over power the needle valves held closes by the floats.
Do one better if you know the light is going to turn red, or as you come to a stop sigh turn the engine off before you stop.
I'm guessing you have a manual transmission?
It only uses more fuel on a cold start with the choke.
