Old 02-27-2020, 10:57 AM   #485 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 50.97 mpg (US)
Vacuum canister possibilities- fire extinguishers have expiration dates and can no longer be used in schools and commercial transportation. There is probably an expired one in your garage. If you need a larger canister, helium canisters for party balloons are single use and could be repurposed.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
MetroMPG (02-27-2020)
