Old 02-28-2020, 09:57 AM   #47 (permalink)
Piotrsko
Probably a design/engineering issue. Typically they require a very small air gap between the rotor and stator. So you end up with bearing wear and thermal expansion issues, which could be resolved by better design and materials. Downside is they get bigger and heavier which increases the unsprung weight, a bad juju consideration.
