Old 02-28-2020, 10:55 AM   #49 (permalink)
oil pan 4
In classical motor design you want as small a gap as possible between the rotor and stator. In smaller motors it's usually 1mm or less. When the bearings start to go you lose control of that gap real quick.
The problem appears to be when you add a motor to a hub it becomes so heavy it beats the bearings to death.
Now on something like a full float barrel bearing in an oil bath like on heavy duty truck axles the bearings should be able to hold up even with a ridiculous amount of mass on either side of the bearings.
It could work on a truck, but no one is going to put huge full float oil bath axles on a car.
It's easier to do what nissan, tesla and GM have all done.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
Flakbadger (02-29-2020), ldjessee00 (02-28-2020)
