Old 03-01-2020, 07:34 PM   #481 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Typically, the incident angle is measured between the line-of-sight and the line normal to the surface, not the surface itself. Snell's Law uses this angle, for instance. Brewster's angle, which is the angle above which light is reflected (and completely polarized) from a surface, is also measured from the normal.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 2 Users Say Thank You to Vman455 For This Useful Post:
freebeard (03-01-2020), Xist (03-05-2020)
