Old 03-21-2020, 11:26 PM   #500 (permalink)
serialk11r
Wow that's low, next mod external EGR? Easy implementation would be a valve that's manually actuated via a pushrod/cable going to the cabin, sized for cruising. I believe it should help a good amount.
My feeling is that ignition timing isn't going to be too critical since the hotter IAT speeds up combustion.
The Following User Says Thank You to serialk11r For This Useful Post:
Ecky (03-21-2020)
