Old 03-17-2020, 04:11 PM   #491 (permalink)
90 day: 81.64 mpg (US)
Update! Engine kill switch complete.
I decided to use the power steering signal, as it's unused in the Insight - this input is for the RSX's hydraulic PS. The way I set it up is as follows:
-Shifter button grounds EPS input
-ECU nitrous control #1 activates
-Nitrous control #1 adds negative 600 fuel units to the fuel map
-ECU momentarily activates the A/C compressor to stop the engine more quickly
Joggernot (03-18-2020)
Old 03-19-2020, 08:39 PM   #492 (permalink)
Was working on all of the cars today. The cam-mirrors return!
New cameras! I like them a lot better than the old ones. Unfortunately they can't be repointed without changing how they're mounted, so my views get a lot of the side of the car now.
New screens! Old ones are on the left. The new ones are lower resolution and smaller, but they're more clear and have better color reproduction. Also, they're 4:3 aspect ratio, like the cameras. The old screens had black bars on left and right. Why are nearly all of the screens for backup cameras widescreen, whereas nearly all of the cameras are 4:3?
The kit, ready to go back in the car:
Mounted up:
Fuel economy after a test run on the highway at ~55mph over 15 miles. Not too shabby!
The Following 6 Users Say Thank You to Ecky For This Useful Post:
COcyclist (03-20-2020), Daox (03-20-2020), deluxx (03-19-2020), Gasoline Fumes (03-19-2020), roosterk0031 (03-21-2020), serialk11r (03-21-2020)
Old 03-19-2020, 10:58 PM   #493 (permalink)
Luddite
deluxx's Avatar
ol-green - '96 Honda Civic LX
90 day: 50.11 mpg (US)
Wonderful! A perfect 2 seater car!
The Following User Says Thank You to deluxx For This Useful Post:
Ecky (03-19-2020)
Old 03-20-2020, 11:34 PM   #494 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
They look great. I wonder if instead of two screen mounted on the dash, if you ever considered one of those windshield mounted rear view mirror screens.
Old 03-21-2020, 08:07 AM   #495 (permalink)
I have, and even tried mounting one or both screens up there. I didn't like the sensation of turning my head right to look for a left hand turn.
Old 03-21-2020, 12:18 PM   #496 (permalink)
Ecky, you said New cameras! I like them a lot better than the old ones. What is the viewing angle of the new cameras? I have a passenger side camera that has a viewing angle of 170 degrees, and I don't find it very satisfying. I bought one that has a 120 degree angle but I haven't had the opportunity to install it.
Old 03-21-2020, 06:34 PM   #497 (permalink)
These are what I got:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The cameras are 135°, which I find to be "about right". I could see going a hair narrower even.
Old 03-21-2020, 09:12 PM   #498 (permalink)
It looks really great. What's your cruising MAP on the freeway?
Old 03-21-2020, 10:12 PM   #499 (permalink)
I get around 380-400mbar at 55mph, 450mbar at 65mph. I want to say idle is ~250mbar so that's what, 20% and 25% load?
Old 03-21-2020, 11:26 PM   #500 (permalink)
Wow that's low, next mod external EGR? Easy implementation would be a valve that's manually actuated via a pushrod/cable going to the cabin, sized for cruising. I believe it should help a good amount.
My feeling is that ignition timing isn't going to be too critical since the hotter IAT speeds up combustion.
The Following User Says Thank You to serialk11r For This Useful Post:
Ecky (03-21-2020)
