The tractor engine is a structural component of the tractor.
So, without the engine, how do I hold the front and the back of the tractor together?!?!?
Some tractors, like those in the Farmall brand, use frame rails that bolt from the transmission to the front end.
Farmall was its own brand, but was bought by International Harvester, and then carried on as a brand-name after that.
I figure that the Farmall 300 is the sister tractor to the International Harvester 300 Utility, but it has a frame.
I found a Craigslist ad for some Farmall parts, so I headed over to see if the parts are interchangeable.
