Old 03-27-2020, 09:05 PM   #461 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
There it is, and I thoroughly cleaned the BLACKENED oil off the front of the engine. Hopefully it no longer leaks. Looks clean eh? I repainted the white lettering on the oil filler cap. Make it pretty! I took off heat shield to strip black paint and polish the aluminum for reduced emisivity and higher reflectance.
Valve clearance set for max overlap again, new valve cover gasket, new spark plug hole gasket, new bolt gasket, finished polishing "Honda," and applied boiled linseed oil to the entire cover.
It is a coping mechanism as COVID-19 begins to overrun my county.
Xist (03-28-2020)
