Old 03-29-2020, 08:31 PM   #32 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Originally Posted by HaroldinCR View Post
I am curious how you plan to adapt the motor shaft to the tranny shaft.
Not exactly sure yet.
I do have the gearbox from the Leaf, so I have the female connection that matches the motor driveshaft.
I also plan on having the clutch, as that's the only way to maintain the full independent PTO and and driving system.
The Leaf motor driveshaft is relatively short and the drive end bearing was never designed to hold any significant amount of weight.
At this point, I'm thinking of machining a stub shaft, supporting that with a bearing in a plate and then a hub with the flywheel.
The flywheel will have to be lightened or replaced with a lightweight version.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
