Old 03-30-2020, 02:19 PM   #465 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by MeteorGray View Post
I used to trickle water from a glass coke bottle into the carb of a fast-idling engine to get that cloud of smoke....
I think a spray bottle into the throttle body would produce just as good atomization as the Sea Foam spray nozzle.
I also now suspect that the benefit was probably uneven. The nozzle was spraying sea fom onto the throttle body ahead of the plate toward the driver side of the opening, rather than dead center. Driver side corresponds with cylinder 1 and 2, which are the two that misfired upon startup. I suspect 3 & 4 did not get as much of the treatment. That make sense?
