Old 04-02-2020, 05:37 AM   #4 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.53 mpg (US)
ALso, funny this gets moved here. It's really not a hybrid. It's exactly the same as an I3 with range extender. The engine is just an onboard generator. I say it's an electric car as it only has electric drive.
While this is true, one might call the Accord Hybrid and 3rd gen Insight "EVs with range extenders" as well, because the engine only acts as a generator, with no direct connection to the wheels*. Only issue is, the battery in them is only ~1kwh, or good for maybe 3 miles without the engine running.
*Granted, above 60mph or so there's a clutch that can, in fact, send engine power to the wheels through a single speed reduction. However, the Versa Note Hybrid is essentially the same, a Leaf motor paired with a tiny ~1kwh battery and an engine which has no connection to the wheels.
Semantics, really. There are a lot of shades between EV and hybrid.
