Old 04-02-2020, 11:40 PM   #9 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Originally Posted by Daschicken View Post
You can change how soon/late the top ratio is reached, but you can’t really change the top ratio.
Yes, roller weight primarily changes how quickly gearing changes but it can also change the final ratio. That happens if the lighter rollers don't weigh enough to fully close the variator to the narrowest width / largest diameter.
You can also change final gearing by changing gears
https://scooterswapshop.com/collecti...-gear-set-zuma
Or you can buy variators and clutches with different ramps for different ratios.
GY6 150 Rear Torque Plates
It isn't as easy as changing a sprocket on a motorcycle and adjusting the chain but you can change overall gearing on a scooter with a CVT.
