03-29-2020, 06:55 AM
Are scooters viable for high milage vehicle?
Maximum MPG with streamlined fairing, 70 mph.
Does anyone have recommendations for suitable scooter?
Pros:
Nonrestrictive frame allowing for smaller fairing.
Engine does not get in the way of legs being close together.
No foot controls to bother with
Small wheels easier to streamline
Cons:
CVT gearing can't be changed RPM can't be reduced?
Heavier than manual motorcycle
Small wheels higher rolling resistance and bumpier ride
03-29-2020, 10:29 AM
マット
Have you seen this?
https://ecomodder.com/forum/showthre...diy-11970.html
There are a few other threads, but the lack a conclusion from what I've seen.
It doesn't address the cvt and it has larger wheels though.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
03-29-2020, 06:06 PM
For me the major downside of a scooter, besides not being so great to haul the dog around, is the fuel capacity usually smaller than in a more conventional motorcycle.
03-29-2020, 08:34 PM
Wanting more for less
I've seen a guy riding a scooter down the mountains and along the motorway while I'm going to work lately.
I haven't been close enough to see what model it is (he rides a bit faster than I drive), but it looks like one of the Yamaha Burgman range.
My point is, even with his high vis vest flapping in the breeze and standard bodywork, these things handle motorway speeds OK.
If you started with a 250cc version and improved aero a bit, it could handle any legal speeds NSW has to offer and return pretty good MPG while doing it.
03-29-2020, 08:38 PM
A small fuel tank is not an issue if you get a 235-470MPG+.
Originally Posted by M_a_t_t
I have the Australian version of this motorcycle NBC110 Honda Super Cub. It's a hassle to deal with the foot controls which is why I am considering a scooter.
03-30-2020, 03:05 AM
Depends on the scooter in some cases. A Honda Reflex 250 project I am back to working on again has a taller Polini gear set installed. (Malossi has an even taller gear set for the Reflex) It also has a much larger than stock passenger vehicle tire (car tire) installed as well. All with the aim of lowering engine rpms.
But that is not without some drawback. I actually need to use a different car tire that is a bit shorter (I have one, just not installed yet) or go back to the standard final drive gears. The test ride I did with both the extra tall tire and taller gears had the engine lugging... So, too much of a good thing not being too good really.
Wheels vary between scooters as well. (though still shorter than conventional motorcycle wheels in most cases) Honda Helix(144cc) has 10" wheels - Reflex(249cc) 12"R, 13"F - Silverwing 600 13"R, 14"F - Suzuki Burgman 650 14"R, 15"F for examples.
For an idea of what can be done, check into this:
Craig Vetter Fuel Economy Challenge. better mileage. Living better on less energy
_______________________________
Southeast Michigan Dark Side Rider
4 Honda Reflex scooters & PS250 Big Ruckus
Originator of the "Darkside" Honda Reflex.
"Yeah dude, that IS a car tire there on the back of my scooter."
Sometimes I'm so far outside of the box, the Hubble telescope can't find me
03-30-2020, 01:00 PM
AKA - Jason
Originally Posted by Spaghetti Man
Cons:
You change RPM / gearing by changing roller weight.
I just bought some lighter weights for my MP3 500 for more aggressive gearing.
http://www.scooterfocus.com/scooter_...er_weight.html
04-02-2020, 03:10 PM
EcoModding flying lizard
Check out the NC700X if you haven’t already. It is not an underbone, but it has an available auto transmission.
HHOTDI has a thread on his manual version, already broke 100 MPG. Last I heard he was supposed to be working on streamlining, but I haven’t seen updates in a while.
https://ecomodder.com/forum/showthre...6-a-36434.html
Originally Posted by JSH
You can change how soon/late the top ratio is reached, but you can’t really change the top ratio.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
Originally Posted by MetroMPG
You can lead a fashion-conscious horse to unusual-looking water...
04-02-2020, 11:40 PM
#9 (permalink)
AKA - Jason
Yes, roller weight primarily changes how quickly gearing changes but it can also change the final ratio. That happens if the lighter rollers don't weigh enough to fully close the variator to the narrowest width / largest diameter.
You can also change final gearing by changing gears
https://scooterswapshop.com/collecti...-gear-set-zuma
Or you can buy variators and clutches with different ramps for different ratios.
GY6 150 Rear Torque Plates
It isn't as easy as changing a sprocket on a motorcycle and adjusting the chain but you can change overall gearing on a scooter with a CVT.
04-03-2020, 01:03 AM
#10 (permalink)
Burgman is a Suzuki, not a Yamaha.
In most jurisdictions a 250cc scooter is already enough, even with stock bodywork.
