Old 04-05-2020, 02:28 AM   #35 (permalink)
Daschicken
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Originally Posted by Tahoe_Hybrid View Post
It has very aggressive DFCO. That is how i'm able to get that many mpg in the first place..
I suspect the Electrical motor is spinning the engine in DFCO... with a OBD reader you can see 0.00v on the upstream o2 sensor. that mean no fuel to air ratio.
when i first saw that i thought my sensor was broken or some other issue..
since there is no "engine braking"
it feels like it's in "neutral gear"
if I shift it into Manual Mode it has "engine braking" and you stop pretty quickly
Are you saying aggressive as in, it barely slows down? I would interpret aggressive as sudden and strong braking action.
The scangauge says my Accord is open loop when DFCO'ing. I don't have the capabilities for monitoring sensor voltage. DFCO in general means cutting fuel while slowing down. The electric motor doesn't have to help spin the engine, as the momentum of the vehicle is already doing that. It may be true that the motor is helping spin the engine under DFCO, but it is also likely that manual mode causes regen, resulting in that increased braking feel.
The new energy saver tires with normal 34 to 36psi get the same milage as the warn out ecopia tires with 44psi.
That's good, cause i've got some worn ecopias and am about ready to swap to the energy savers.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
