Old 04-06-2020, 04:37 PM   #646 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Originally Posted by Xist
How do you disable a respirator valve?
If you do that then it is safer for everyone.
You don't. Doing so would mean you would have to exhale through the filter, which is restrictive, which means you will build up CO2 inside the mask. (You can actually get masks that do this on purpose simulate training at a higher altitude)
The most likely scenario with the valve blocked is that you exhale through leaks around the mask and then suck air back in through those leaks before they close again. Cover the valve and exhale and you will see what I'm talking about.
There's no need for masks if people with coughs just stayed home. Masks aren't primarily for the healthy, but for the unhealthy to prevent further spread.
Not true. 25% of people with COVID 19 have no symptoms but are still spreading it through the air when they breath and talk.
