Your image was taken too close to the car, altering what Honda's design would reflect from a telecamera or blueprint....
Is there a known method for producing the proper scale when taking a photo? Like, a certain distance away the camera should be or how high?
I'd definitely be able to seal the edge of any spoiler/sing to the glass and I'd be interested in potential gains based on a properly scaled image.
All the different elements interact with each other and make "one size fits all" simplicity impossible. Experiment.
Thought you might say that.
I'm definitely wanting to play around with the idea and see how the numbers shake out. You used two sided tape for a test fit/run, correct?
