Old 04-08-2020, 04:54 PM   #43 (permalink)
freebeard
I'm not sufficiently skilled or equipped to create a compound curve...
The best potential improvement would be to project the curve of the shed's top corners to the forward ends of the outer trusses. This would be a simple curve.
Else you could start with a triangle and bend the tips or slit and overlap as necessary to make a shallow cone shape.
Interstatement (04-21-2020)
