Old 04-10-2020, 03:20 PM   #15 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
I'm 1/2 way through my 2nd trip without charging or about 10 miles and it's still showing 4/5ths. I'll definitely charge it at home tonight. They say 25-45 miles and I'm going to easily get the 25 and I am running max pedal assist. I have a small 60' hill on the way home and a gradual 20' gain on the way to work. I pedal, but not that hard, and have about 4-5 stops I have to make on 3.5 trip each way. I should check the voltage when i get home and then after a full 12 hr charge and see exactly what I'm using. The gauge is to simple to show voltage.
That table does look like 20% is the sweet spot. 10% gets you more cycles but not twice the 20% which would happen 1/2 as often.
