04-08-2020, 07:54 AM
#11 (permalink)
You could change out the controller for a programmable one.
My velomobile topped out around 50mph, but I had a programmable controller which I set up to allow a speed cap in 5mph increments. It was great for letting strangers/children ride in it without risking they'd take out a tree or telephone pole.
04-08-2020, 07:00 PM
#12 (permalink)
Well I rode it to work for the first time and then ordered a suspension seat post and a new seat off Amazon while I was waiting to clock in. It actually wasn't that bad but why not make it better. It took me an extra 5-6 mins longer each way compared to driving, but when traffic gets busy again after the shutdown I bet the ride home may even save a minute or two. It did save me $.67 in diesel so just 1654 more trips and this thing has paid for itself! Oh wait I need 100 more that that to buy the new suspension seatpost and seat. The battery was just starting to show 4/5 bars on the hill home but once I stopped it went back to 5/5 bars. Don't know exactly what that means but am guessing I could probably go a week between charging although I'll probably do it every 2-3 days. I'm charging tonight because they say do 3, 12 hour exactly charges to initially balance the battery and I want to get that out of the way.
04-09-2020, 09:51 AM
#13 (permalink)
If it's below 70 degrees, expect the slow return. It's chemical after all.
Do the 3 charge cycles, but don't expect that to equalize the pack. The cells have to be done one by one either top or bottom balance.
04-10-2020, 11:40 AM
#14 (permalink)
AKA - Jason
I'll be curious to see how you like. I see quite a few Rad Runners and Rad Wagons around here and they seem to be a good mix of quality and cost.
I think there is a e-bike in my future but I want a mid-drive with and internal hub which means I will likely need to build my own. I'm torn between a small gas motorcycle vs an e-bike for full time van life.
If you are using 20% of the battery SOC per day I would charge every night. Charging every 3 days (60%) will reduce battery by about 1/2. According to this chart discharging to 20-40% is optimal for battery life.
The charge comes from: https://batteryuniversity.com/learn/...ased_batteries
The Following User Says Thank You to JSH For This Useful Post:
04-10-2020, 03:20 PM
#15 (permalink)
I'm 1/2 way through my 2nd trip without charging or about 10 miles and it's still showing 4/5ths. I'll definitely charge it at home tonight. They say 25-45 miles and I'm going to easily get the 25 and I am running max pedal assist. I have a small 60' hill on the way home and a gradual 20' gain on the way to work. I pedal, but not that hard, and have about 4-5 stops I have to make on 3.5 trip each way. I should check the voltage when i get home and then after a full 12 hr charge and see exactly what I'm using. The gauge is to simple to show voltage.
That table does look like 20% is the sweet spot. 10% gets you more cycles but not twice the 20% which would happen 1/2 as often.
04-10-2020, 10:23 PM
#16 (permalink)
Do you have a charger that can stop at 80%? That's where the big gains are, not going all the way to 0% or 100%.
The flat discharge curve for lithium makes it difficult to estimate the charge based on voltage. I used a watt meter like this for my ebike to keep track of how much power I used. http://amazon.com/GT-Power-Analyzer-...dp/B00C1BZSYO/
04-11-2020, 07:48 AM
#17 (permalink)
I had a watt meter just like that for my other bike and it died. The other bike was a 52 volt so maybe it was too much at 100% charge? Maybe it was just a bad unit as it only lasted a week.
I was wondering how to figure out how to stop charging at 80% and then just charge every day after riding. The supplied charger gives no clue. Maybe I'll just get a time down. Maybe I'll just not worry so much and be happy with whatever. Batteries are getting less expensive still.
Looks like a 12 hr charge goes to 53.7 volts on a 48v battery so 95% according to the chart I found? At least that's not 100%
04-11-2020, 10:12 AM
#18 (permalink)
There are many cheap voltage displays that have a smart programmable switching option using relays which could be used inline between the charger and the battery.
Charts are inaccurate, as is bulk charging for determining SOC on series banks.
04-11-2020, 11:13 AM
#19 (permalink)
So if a 20% discharge is best and limit to 80% max is best, does that mean you run 80% down the 60% and then recharge to 80% for best life?
The Following User Says Thank You to Hersbird For This Useful Post:
04-12-2020, 11:09 AM
#20 (permalink)
That is what empirical testing the last ten years indicate
