Old 04-13-2020, 11:50 AM   #4 (permalink)
redpoint5
90 day: 29.78 mpg (US)
I store up to 500 gallons in 2 above ground containers. I used to get fuel for $1/gallon and the containers were given to me, so it was easily justified.
You'll need a pump, hose, nozzle, filter, and flow meter if you're interested in metering how much fuel you deliver. That all adds up.
I don't have problems with growth in the fuel and don't treat it with anything. That said, I don't draw off the bottom of the tank (I draw about an inch from the bottom) and have a filter.
In ground is probably better since it regulates temperature and blocks sunlight.
