Old 04-13-2020, 12:17 PM   #5 (permalink)
oil pan 4
Diesel can be stored for years. When I was in japan all buildings has backup diesel generators. The diesel fuel tanks held 100 to 500 gallons and it never got replaced. Every 6 months each generator would get fired up for 30 minutes and that was it. Then the tanks would get topped off when they got below the full mark.
The larger tanks likely take 20 years to burn through.
Definitely don't try to store bio diesel.
When I was in Langely I stored a 55 gallon drum for most of the time I was living there, from 2006 to 2011. I filled it up some time by mid 2006, used some when diesel prices went stupid high in 2007 to 2008, then finished it off when I moved in 2011.
I have a 500 gallon propane tank I want to turn into a diesel tank.
Just going to weld a stainless 2 inch NPT half coupler on the top so I can drop my old "55 gallon barrel pump" in there which I got for free, weld a stainless 1/2 inch NPT bung on the bottom to drain off water.
Everyone who has the space and lack of stupid state laws should store some fuel.
Xist (04-19-2020)
