Old 04-16-2020, 03:01 PM   #8 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Welcome Green. It's good to see another diesel on here. I would start with tire pressure, ScanGuage and upper grill blocking. I did mine with black insulation foam for plumbing pushed between the slats. It is easy to remove if needed but I have never felt the need in 15 years.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
