Old 04-19-2020, 09:24 PM   #7 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I’m curious. Did you use the same rim and tire combination with and without a flat covering?
The short answer is Yes. I tried multiple combinations and the best of all were the alloy rims bare followed by the same tire and rim with a flat coroplast cover which was consistently worse.
More to come.
Edit- If this were a newspaper I would be printing a retraction. I posted the quick reply to the question above before looking at my notes. As I was entering the test data last night I realized that the coroplast wheel covers edged out the bare alloys by 1 mpg.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
