Old 04-19-2020, 10:50 PM   #8 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Unhappy Test Data Day One
Kudos to anyone who decides to do A-B-A testing. To do it right takes time and ideal test conditions to get good results. This testing was done over 2 days. I chose a long straight road with very little traffic and open fields on both sides. The runs were almost 2 miles in each direction at about 62 mph or 100 kph. Day one the temperature was 44 degrees with a 7 mph wind from the west. The road goes east west. I averaged the east and west runs together. I used cruise control and left the car running while I added or removed wheel covers and used the same start and stop points for all runs. I used the ScanGuage set to current MPG and reset it at the start point with the car up to speed and cruise resumed.
My A runs were with factory steel rims and the factory wheel covers with worn snow tires. The B runs were the same wheel and tire combination but with the wheel covers off.
A1 east/west average mpg- 54.7
B1 east/west average mpg- 57.85 (this was just the black steel rims)
B2 east/west average mpg- 53.6
A2 east/west average mpg- 55.85
I averaged all the A runs and all the B runs and got 55 mpg and a few decimal points for both. There seemed to be more variation with changing wind perhaps, than the variation of wheel covers on or off.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
aerohead (04-22-2020)
