Old 04-20-2020, 11:56 AM   #45 (permalink)
Interstatement
Unfortunately, a cracked radiator has pulled me away from the fun stuff. Need to repair the lower rad mounts to avoid a repeat, but may take the opportunity to delete the factory clutch fan in favor of a later Ranger electric fan and shroud. The donor trucks for both the radiator and the fan/shroud were air-conditioned, unlike mine, so the improved cooling capacity should make future grill-blocking a low-risk proposition.
The Following User Says Thank You to Interstatement For This Useful Post:
aerohead (11-11-2020)
