Old 04-28-2020, 11:56 AM   #5 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Check this out:
https://www.motorauthority.com/news/...-racing-engine
One way engineers were able to extract more efficiency from the powertrain is by using a motor-generator unit heat, which recaptures waste heat from the exhaust and converts it to electric power. That wasted exhaust heat spools up a compressor that spins an electric motor, which sends electricity to a battery that powers another electric motor to add torque to the rear wheels. Mercedes also pioneered the split turbocharger, which keeps the unit cooler and allows the car to use a smaller intercooler design with less intake piping.
Exhaust heat recovery works, but it's typically some combination of complicated, heavy, large and expensive. I'm guessing with the Mercades F1 unit, it's mostly complicated and expensive.
