Originally Posted by redpoint5
I've mentioned this elsewhere, but I've been running a LiFePO4 in my 2012 Prius for 4 years now. Since PDX is fairly mild, and the battery lives inside the cabin, it seems to work well.
Not sure if it would be appropriate for Wisconsin if the cabin gets well below freezing for longish periods of time. If it were me, I'd probably be willing to try it just as an experiment. That's essentially what I did considering I had no other examples of people doing what I had done.
https://www.batteryspace.com/lifepo4...assed-dgr.aspx
Search for coupon codes for things like 10% off.
I actually ran this exact battery for 2 winters in Vermont. The first winter I had supercaps starting the engine and the battery sat behind a very low ohm resistor, just to keep the caps topped off. Second winter I just used it as a starter battery, and it held up.
Not that I advise this.
LiFePO4 isn't going to explode from mis-treating it, but it's an expensive battery to kill.
